Graphing Software
Home Forums Other Data Loggers Graphing Software
Viewing 4 reply threads
    • #1348
      prairietech
        Looking for an easy to use (low learning curve) graphing program that will display 1-3 inputs. I would like to have the cursor hovering ability to display data points from the inputs to compare readings. Input data would come from a mysql db or csv file located on a local server.
      • #1349
        Andrew
          Would Highcharts be suitable?
        • #1372
          prairietech
            I have looked at Highcharts but when hovering the mouse over a data point on the graph, only that data point value and time stamp were displayed. I needed to move my mouse to each input graph line to see the data point value for that input.
            My desire is to have 1-3 inputs displayed on a graph. Hovering my mouse would show a data point balloon listing values (temp) for all 1-3 inputs at that particular time for comparison. Maybe this is a function of Highcharts but I couldn’t find any information regarding this feature.
          • #1411
            Tyler Mitchell
              Depending on your data source, you might really like Grafana – my go-to favourite. I used InfluxDB time series DB in the backend and it plugs in seamlessly.
              [video is no longer available]
            • #1470
              Steve Roberts
                I’ve been using flot, which uses jquery, as my website was already using jquery. Data comes from mysql / php
