Analog-to- Digital Converter Port on Mayfly Data Logger
Home Forums Mayfly Data Logger Analog-to- Digital Converter Port on Mayfly Data Logger
Viewing 4 reply threads
    • #13174
      Rachana
        Hello @shicks,
        I am trying to connect the OBS 3+ of Campbell Scientific(turbidity sensor) to the Mayfly Data Logger using the ‘Auxiliary 16-bit, 4-channel Analog-to-Digital Converter’ port.
        Mayfly board has been powered up by connecting it to a PC via USB. It receives 5V external input when connected to ‘LiPo battery connector’ port. But when trying to power up the turbidity sensor by connecting to the ‘Auxiliary 16-bit, 4-channel Analog-to-Digital Converter’ port, there is 0V at that port. Any help with information about how to connect the sensor to the Mayfly board is highly appreciated.
        Thank you.
      • #13175
          Are you referring to the two Grove ports in the lower left corner of the Mayfly? All of the Grove ports (and the Sw3 and Sw5 pins in the headers) are designed to only be powered when you set pin D22 high. This is so that you can turn any external sensors on or off independently from other things on the Mayfly. Setting D22 high turns on the external 3v and 5v regulators, and anytime they are on you’ll see a red LED in the corner of the board light up (LED3).
          Also be aware that the maximum incoming voltage that the ADS1115 can read is 3.3v, as determined by the Vcc of the Mayfly. You can buy the OBS3+ in different voltage output options, so if you bought the one with 5v output at full scale, you’ll need to use a voltage divider to protect the Mayfly from seeing anything greater than 3.3v. We always buy the OBS3+ with the 2.5v output option so that the max voltage will never exceed Vcc. And if you do use a voltage divider, make sure to account for that in the formula you use for the ADS1115 to convert bits to volts which and translate into sensor output to match up with the sensor calibration equations provided with each sensor.
          • #13176
            Rachana
              Thank you for the information. But I am unable find the D22 pin on the board. I am using ver 0.5b. I checked the schematic and tried locating the TOSC1/D22 but could not. Could find all the resistors and capacitors in the 3.3V switched and 5V boost circuit except the D22 enable pin. Also, how to set the pin high if located? Thank you.
          • #13181
              You set pin 22 high in whatever program/sketch you’re using.
            • #13182
                Mayfly D22 is not a physical pin on the board, it’s processor pin 22, which means you set it high or low using digitalWrite commands in your sketch, just like you would with pin 8 or 9 to turn the red or green LEDs on or off. If you’re new to Arduino or the Mayfly, you might try working through example sketches or workshop sketches in our Github repo to familiarize yourself with the operation before you connect an expensive sensor like an OBS3 to a Mayfly.
              • #13222
                Rachana
                  Thanks for the guidance. I went through the examples in the git repo and found the following piece of code (abridged for Campbell OBS3+ turbidity sensor). I have a couple of questions. Could you please help me with them?
                  1. The OBS3+ I am using operates at 5V and it needs D22 pin. Pin D22 is enabled in the code. But how to mention in the code that it is switched to 5V? Below are the code lines where I could get a reference for D22 and greater than 3.3V(5V in this case)
                  float getBatteryVoltage()
                  if (mcuBoard.sensorValues[0] == -9999) mcuBoard.update();
                  return mcuBoard.sensorValues[0];
                  const int8_t sensorPowerPin = 22
                  // Create the log file, adding the default header to it
                  // Do this last so we have the best chance of getting the time correct and
                  // all sensor names correct
                  // Writing to the SD card can be power intensive, so if we’re skipping
                  // the sensor setup we’ll skip this too.
                  if (getBatteryVoltage() > 3.4)
                  dataLogger.turnOnSDcard(true); // true = wait for card to settle after power up
                  dataLogger.createLogFile(true); // true = write a new header
                  dataLogger.turnOffSDcard(true); // true = wait for internal housekeeping after write
                  2. As the voltage is more than 3V- a voltage regulator is needed. Does the line below help? Does pin A6 work as a voltage divider?
                  const int8_t resistorDividerPin = A6; //Resistor divider on the battery input of Mayfly board
                  3.I am trying to connect the sensor to the grove pins ‘Analog to Digital Convreter pins- AA0 and AA1’.
                  “const uint8_t ADSi2c_addr = 0x48; // The I2C address of the ADS1115 ADC” — is this statement in the code enough to get output from ports AA0 and AA1.
                  4. The lines below say that a log file will be created.
                  “dataLogger.createLogFile(true); // true = write a new header” —>Does this mean I have to write another header in the code or does it print the sample values under a default header?
                  Could you please guide on what additions and modifications are needed to the code?
                  obs3+.ino
                  Written By: Sara Damiano (sdamiano@stroudcenter.org)
                  Development Environment: PlatformIO
                  Hardware Platform: EnviroDIY Mayfly Arduino Datalogger
                  Software License: BSD-3.
                  Copyright (c) 2017, Stroud Water Research Center (SWRC)
                  and the EnviroDIY Development Team
                  This example sketch is written for ModularSensors library version 0.21.2
                  This sketch is an example of logging data to an SD card as should be used by
                  groups involved with The William Penn Foundation’s Delaware River Watershed
                  Initiative at sites without cellular service.
                  DISCLAIMER:
                  THIS CODE IS PROVIDED “AS IS” – NO WARRANTY IS GIVEN.
                  // Include the base required libraries
                  #include <Arduino.h> // The base Arduino library
                  #include <EnableInterrupt.h> // for external and pin change interrupts
                  // Data Logger Settings
                  // The library version this example was written for
                  const char *libraryVersion = “0.21.2”;
                  // The name of this file
                  const char *sketchName = “obs3+.ino”;
                  // Logger ID, also becomes the prefix for the name of the data file on SD card
                  const char *LoggerID = “XXXXX”;
                  // How frequently (in minutes) to log data
                  const uint8_t loggingInterval = 5;
                  // Your logger’s timezone.
                  const int8_t timeZone = -5; // Eastern Standard Time
                  // NOTE: Daylight savings time will not be applied! Please use standard time!
                  // Primary Arduino-Based Board and Processor
                  #include <sensors/ProcessorStats.h>
                  const long serialBaud = 115200; // Baud rate for the primary serial port for debugging
                  const int8_t greenLED = 8; // MCU pin for the green LED (-1 if not applicable)
                  const int8_t redLED = 9; // MCU pin for the red LED (-1 if not applicable)
                  const int8_t buttonPin = 21; // MCU pin for a button to use to enter debugging mode (-1 if not applicable)
                  const int8_t wakePin = A7; // MCU interrupt/alarm pin to wake from sleep
                  // Set the wake pin to -1 if you do not want the main processor to sleep.
                  // In a SAMD system where you are using the built-in rtc, set wakePin to 1
                  const int8_t sdCardPwrPin = -1; // MCU SD card power pin (-1 if not applicable)
                  const int8_t sdCardSSPin = 12; // MCU SD card chip select/slave select pin (must be given!)
                  const int8_t sensorPowerPin = 22; // MCU pin controlling main sensor power (-1 if not applicable)
                  // Create the main processor chip “sensor” – for general metadata
                  const char *mcuBoardVersion = “v0.5b”;
                  ProcessorStats mcuBoard(mcuBoardVersion);
                  // Maxim DS3231 RTC (Real Time Clock)
                  #include <sensors/MaximDS3231.h>
                  // Create a DS3231 sensor object
                  MaximDS3231 ds3231(1);
                  // CAMPBELL OBS 3 / OBS 3+ Analog Turbidity Sensor
                  #include <sensors/CampbellOBS3.h>
                  const int8_t OBS3Power = sensorPowerPin; // Pin to switch power on and off (-1 if unconnected)
                  const uint8_t OBS3numberReadings = 10;
                  // Campbell OBS 3+ Low Range calibration in Volts
                  const int8_t OBSLowADSChannel = 0; // The ADS channel for the low range output
                  const float OBSLow_A = 0.000E+00; // The “A” value (X^2) from the low range calibration
                  const float OBSLow_B = 1.000E+00; // The “B” value (X) from the low range calibration
                  const float OBSLow_C = 0.000E+00; // The “C” value from the low range calibration
                  // Create a Campbell OBS3+ LOW RANGE sensor object
                  CampbellOBS3 osb3low(OBS3Power, OBSLowADSChannel, OBSLow_A, OBSLow_B, OBSLow_C, ADSi2c_addr, OBS3numberReadings);
                  // Campbell OBS 3+ High Range calibration in Volts
                  const int8_t OBSHighADSChannel = 1; // The ADS channel for the high range output
                  const float OBSHigh_A = 0.000E+00; // The “A” value (X^2) from the high range calibration
                  const float OBSHigh_B = 1.000E+00; // The “B” value (X) from the high range calibration
                  const float OBSHigh_C = 0.000E+00; // The “C” value from the high range calibration
                  // Create a Campbell OBS3+ HIGH RANGE sensor object
                  CampbellOBS3 osb3high(OBS3Power, OBSHighADSChannel, OBSHigh_A, OBSHigh_B, OBSHigh_C, ADSi2c_addr, OBS3numberReadings);
                  // Creating the Variable Array[s] and Filling with Variable Objects
                  #include <VariableArray.h>
                  Variable *variableList[] = {
                  new CampbellOBS3_Turbidity(&osb3low, “12345678-abcd-1234-efgh-1234567890ab”, “TurbLow”),
                  new CampbellOBS3_Turbidity(&osb3high, “12345678-abcd-1234-efgh-1234567890ab”, “TurbHigh”),
                  new ProcessorStats_Batt(&mcuBoard, “12345678-abcd-1234-efgh-1234567890ab”),
                  new MaximDS3231_Temp(&ds3231, “12345678-abcd-1234-efgh-1234567890ab”)
                  // Count up the number of pointers in the array
                  int variableCount = sizeof(variableList) / sizeof(variableList[0]);
                  // Create the VariableArray object
                  VariableArray varArray(variableCount, variableList);
                  // The Logger Object[s]
                  #include <LoggerBase.h>
                  // Create a new logger instance
                  Logger dataLogger(LoggerID, loggingInterval, &varArray);
                  // Device registration and sampling feature information
                  // This should be obtained after registration at http://data.envirodiy.org
                  // This is needed so the logger file will be “drag-and-drop” ready for manual
                  // upload to the portal.
                  const char *registrationToken = “12345678-abcd-1234-efgh-1234567890ab”; // Device registration token
                  const char *samplingFeature = “12345678-abcd-1234-efgh-1234567890ab”; // Sampling feature UUID
                  // Working Functions
                  // Flashes the LED’s on the primary board
                  void greenredflash(uint8_t numFlash = 4, uint8_t rate = 75)
                  for (uint8_t i = 0; i < numFlash; i++) {
                  digitalWrite(greenLED, HIGH);
                  digitalWrite(redLED, LOW);
                  delay(rate);
                  digitalWrite(greenLED, LOW);
                  digitalWrite(redLED, HIGH);
                  delay(rate);
                  // Read’s the battery voltage
                  // NOTE: This will actually return the battery level from the previous update!
                  // Main setup function
                  void setup()
                  // Start the primary serial connection
                  Serial.begin(serialBaud);
                  // Print a start-up note to the first serial port
                  Serial.print(F(“Now running “));
                  Serial.print(sketchName);
                  Serial.print(F(” on Logger “));
                  Serial.println(LoggerID);
                  Serial.println();
                  Serial.print(F(“Using ModularSensors Library version “));
                  Serial.println(MODULAR_SENSORS_VERSION);
                  if (String(MODULAR_SENSORS_VERSION) != String(libraryVersion))
                  Serial.println(F(
                  “WARNING: THIS EXAMPLE WAS WRITTEN FOR A DIFFERENT VERSION OF MODULAR SENSORS!!”));
                  // Set up pins for the LED’s
                  pinMode(greenLED, OUTPUT);
                  pinMode(redLED, OUTPUT);
                  // Blink the LEDs to show the board is on and starting up
                  greenredflash();
                  // Set up some of the power pins so the board boots up with them off
                  // NOTE: This isn’t necessary at all. The logger begin() function
                  // should leave all power pins off when it finishes.
                  if (sensorPowerPin >= 0)
                  pinMode(sensorPowerPin, OUTPUT);
                  digitalWrite(sensorPowerPin, LOW);
                  // Set the timezone and offsets
                  // Logging in the given time zone
                  Logger::setTimeZone(timeZone);
                  // Offset is the same as the time zone because the RTC is in UTC
                  Logger::setTZOffset(timeZone);
                  // Attach information pins to the logger
                  dataLogger.setLoggerPins(wakePin, sdCardSSPin, sensorPowerPin, buttonPin, greenLED);
                  dataLogger.setSamplingFeatureUUID(samplingFeature);
                  // Begin the logger
                  dataLogger.begin();
                  // Set up the sensors, except at lowest battery level
                  Serial.println(F(“Setting up sensors…”));
                  varArray.setupSensors();
                  // Call the processor sleep
                  Serial.println(F(“Putting processor to sleep”));
                  dataLogger.systemSleep();
                  // Main loop function
                  // Use this short loop for simple data logging and sending
                  void loop()
                  // Note: Please change these battery voltages to match your battery
                  // At very low battery, just go back to sleep
                  if (getBatteryVoltage() < 3.4)
                  // If the battery is OK, log data
                  else dataLogger.logData();
