Home › Forums › Mayfly Data Logger › Connecting Bare Wire Sensor to Jack Adapter
- This topic has 7 replies, 4 voices, and was last updated 2021-03-08 at 12:41 PM by Cheryl Nolan.
2021-03-04 at 3:35 PM #15203
I have a bare 4-wire CTD sensor and and adapter with 4 connection points (screw terminals). How do I know which wire goes to which terminal. I see where the ground connects at GND (see photos) but the other three are a mystery.
2021-03-04 at 4:02 PM #15206
For a Meter Hydros 21 sensor, check the manual that came with the sensor to double-check that they haven’t change the wiring colors lately, but the usual pattern is red is data, white is power, and black is ground. So connect red to D2, white to Vcc, and black to GND. For that screw terminal board, D2 will get connected to D7 if you plug the grove cable into the D6-7 socket on the Mayfly board. We usually use the Mayfly’s D7 pin for SDI-12 sensors in all our sample code.
2021-03-05 at 8:10 AM #15209
Shannon, I received 3 Meter CTD-10 (HYDROS 21) sensors this week and they did change the wire colors. For me brown is power (VCC) and orange is data (D2). I also had to use the b_address_change sketch to change the SDI-12 address from 0 to 1.
2021-03-05 at 9:10 AM #15210
Brian, when they did this color change did they give you a pinout? (I love when they do this…)
2021-03-05 at 9:14 AM #15211
They did not give me a pinout, I just did trial and error of figure it out. I think next time I’ll purchase a stereo jack adaptor and try connecting it to the Mayfly that way.
2021-03-05 at 9:20 AM #15212
Thanks for the info Brian. I heard they were switching cable outer jacket colors soon, and a few of our workshop attendees last month received Hydros 21 sensors with black cable instead of the usual red, so I’m assuming the inner wire color changed too. Their soil moisture sensors also changed inner wire colors a few years ago, and the manual shows both options. It’s always good practice to double-check with a manufacturer if it’s unclear what wires to connect to a datalogger because some sensors can be damaged by connecting them to the wrong pins. The Meter Group sensor seem to be pretty hearty and I haven’t accidentally broken one by connecting it wrong, but I’ve used other sensors that were immediately bricked by hooking it up wrong.
2021-03-05 at 9:23 AM #15213
Shannon, yes, the outer jacket color I received is black. Good to know about the possibility of sensor damage or bricking.
2021-03-08 at 12:41 PM #15223
I called Meter Group tech support because my manual only showed the 3.5mm jack connection, bare wires were not addressed and they confirmed your connection, Shannon. (red to D2, white to Vcc, and black to GND) I also had a 4th bare wire that he told me to wrap with electrical tape and tape it out of the way so it can’t cross other connections. He did say that they would be changing the color scheme.
Thanks everyone!
