Welcome to EnviroDIY, a community for do-it-yourself environmental science and monitoring. EnviroDIY is part of WikiWatershed, an initiative of Stroud Water Research Center designed to help people advance knowledge and stewardship of fresh water. New to EnviroDIY?Start here
in platformio.ini, PlatformIO consults its registry to install the library and its dependencies. However, I just noticed that there are two in the registry: one under envirodiy and one under srgdamia1. Presumably envirodiy is the correct one? While it is possible to specify a library owner:
1
lib_deps=envirodiy/EnviroDIY_ModularSensors
it is also valid to omit the owner name, as in the first example above. How can we remove this ambiguity?
