Home › Forums › Monitor My Watershed › Editing Variable UUIDs
- This topic has 54 replies, 4 voices, and was last updated 2020-05-28 at 11:17 AM by
jbiddle.
2019-10-28 at 12:40 PM #13263
I am currently attempting to edit the variable UUIDs in the DRWI_CitSci sketch with those for the sensors that are part of my system. In the sketch there are default UUIDs provided for each variable, including those for a CTD sensor. I’m not using a CTD sensor – can I just delete those lines from my sketch or should I keep them in with the default UUID provided in the sketch?
2019-10-28 at 5:20 PM #13265
Delete them.
2019-11-25 at 11:41 AM #13395
Thanks for your response.
I’ve been out of the office and am just now getting back around to trying to set up our data logger. This is my first time trying to set up one of these data loggers, and possibly more importantly is my first time working with Arduino, so I’m still working on understanding everything.
In the DRWI_CitSci sketch I mentioned, I’m having a few issues verifying/compiling the sketch after editing the UUIDs and a few other variables. In the first few lines of the sketch there is:
#include <Arduino.h> // The base Arduino library
#include <EnableInterrupt.h> // for external and pin change interrupts
#include <LoggerBase.h> // The modular sensors libraryThe error I’m receiving is: Arduino: 1.8.10 (Windows 10), Board: “EnviroDIY Mayfly 1284p”
sketch_nov25a:36:10: error: LoggerBase.h: No such file or directory
Multiple libraries were found for “EnableInterrupt.h”
Used: C:\Users\Owner\Documents\Arduino\libraries\EnableInterrupt
#include <LoggerBase.h> // The modular sensors library^~~~~~~~~~~~~~
compilation terminated.
exit status 1
LoggerBase.h: No such file or directoryThis report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.Where can I find the LoggerBase.h library?
Additionally, another error I’ve run into is for the #include <sensors/ProcessorStats.h> line. Again, no such directory or file found.
If you have any guidance, it would be greatly appreciated. Thanks for your patience and helping work through/learn how to do this!
2019-11-25 at 1:40 PM #13399
It looks like you’re using the Arduino IDE. Managing multiple libraries for the Arduino IDE is NOT easy – it is quite a hassle. Have you installed all the libraries following the instructions here: https://github.com/EnviroDIY/Libraries#installing-libraries-in-the-arduinocc-ide? Have installed them more than one time? When you open your Arduino library folder (likely documents/Arduino/libraries), do you see only one folder for each library. If you see multiple folders with the same names, (ie, EnableInterrupt and EnableInterrupt (2) ) then you do have multiple copies of libraries and must remove the extras. If you have not done any modification of you libraries and you haven’t programmed other boards in a way that you need to be able to reproduce exactly, I would start fresh by deleting everything in your Arduino/libraries folder and reinstalling them all following the directions I linked above. If you’ve modified any other library or you have other programs depending on the exact versions of your installed libraries, you’re going to have to manually go through them and delete the conflicting versions and install anything missing. All of the dependencies for ModularSensors are listed here: https://github.com/EnviroDIY/ModularSensors/wiki/Library-Dependencies (and of course ModularSensors itself is required).
This difficult in managing libraries is the primary reason I would never recommend the Arduino IDE. PlatformIO makes this management much easier, even though it might seem scarier to beginners at the start.
2020-01-07 at 3:43 PM #13539
Hi Sara, thanks for your help.
I unfortunately had to put this project on hold right after you help me with my last problem, so sorry for the late response.
I managed to fix the library issue I was having (they were stored in the wrong subfolder), and I have a few new questions if you are able to help.
When editing the UUIDs for each variable in my sketch, there is supposed to be a UUID for both the low and high values for the Campbell OBS-3+ Sensor (“TurbLow” and “TurbHigh”). However on Monitor My Watershed I only have one UUID for the sensor for my turbidity variable. Is there a way to create a UUID for each of the low and high values on Monitor My Watershed?
Thanks in advance for your help.
2020-01-07 at 4:02 PM #13540
The OBS3+ treats the low range and high range turbidity as if they’re two completely different things. So on Monitor My Watershed you actually have to create two different variables, one for each of the high and low range, just like you would separate temperature and depth from a CTD. I *strongly* recommend you add something to the notes field for each to remind you which is which. Once you’ve create two different variables on Monitor My Watershed, it will give you two different UUID’s.
Here’s another site with the turbidity set up for both high and low range: http://data.envirodiy.org/sites/PKCV7S/
If you really want to have only one turbidity field streaming, you can either pick one of the two or create a calculated variable that picks between the two depending on the turbidity. For most of our sites, we’ve decided to just stream the two separately.
2020-02-06 at 4:38 PM #13762
Hi Sarah,
Thanks for your response. I once again had to put this on hold for a bit but I am back to trying to get it to work.
As I’ve mentioned I am new to this type of thing, but I really think I’ve hit a wall here, and am wondering if I could benefit from a bit more in-depth help. I’ve followed the directions as closely as I could and edited the DWRI_CitSci.ino code as accurately as possible, but when I verify the code I am getting the mother of all error messages and I’m not really sure how to make heads or tails of it. I could post it here but it is very, very long. Is there a way you could continue to help walk me through this process?
2020-02-07 at 5:42 PM #13769
Posting here is really the best way. You can attach the output as a text file.
2020-02-10 at 3:54 PM #13784
Thanks Sara. I’ve copied the error message and attached it as a text file. As you can see there’s a lot going on and I’m not really even sure where to begin. Any advice you have is appreciated. Thanks.
2020-02-10 at 5:00 PM #13787
That’s a lot of compiler errors!
Could you post your program (“sketch_jan07a.ino”)? I’m guessing based on the errors that there might be a stray quotation mark or a missing semicolon somewhere that’s throwing the whole thing off.
It looks like you have also some of the libraries installed multiple times and I’m guessing some might not be installed. Did I mention that library management with the Arduino IDE isn’t easy? That’s it’s biggest downside. ModularSensors has so many dependencies that managing them gets pretty painful pretty fast with the Arduino IDE. (Sorry!) But it is definitely doable!
Can you check your library folder like I described back in November? Again, if you’ve written programs before that you want to work again exactly as they did in the past, you’ll have to crawl through each library checking for versions, but if not you might as well delete them all and start over.
2020-02-11 at 4:29 PM #13800
You did mention that it isn’t easy! I did download PlatformIO and found it to be just as foreign to me, so instead of confusing myself with two different applications I figured I’d stick with the Arduino IDE for now. I just went through and deleted what I thought was my duplicate library, other than that I’m not sure what libraries might be missing as I’ve tried to follow the directions as closely as I could. I’ve attached the sketch. Thanks for taking the time to help me.
2020-02-12 at 8:06 AM #13802
It looks like when you created your sketch, instead of starting with a completely empty file you pasted your code into the middle of the Arduino IDE’s placeholder code. So there are chunks of that at the beginning and end which you need to remove.
From the beginning, delete this :
void setup() { // put your setup code here, to run once: } void loop() { // put your main code here, to run repeatedly:
From the end, delete this :
} // ========================================================================== // Main loop function // ==========================================================================
The last line in your code should be a closing curly brace.
2020-02-12 at 8:24 AM #13803
If you are still getting library compiler errors after fixing your sketch, I would strongly prefer to guide you through using PlatformIO. It really is easier, even though it feels much more “programmer” then the more “hobbiest” Arduino IDE.
Very , very briefly:
- Open the “PlatformIO home”, and create a new project
- After your project is created, delete the contents of the new platformio.ini file and replace them with the contents of the same file from the folder where you copied your code from on GitHub
- Delete the contents of src/main.cpp and replace it with your corrected sketch
- Open the PlatformIO menu (looks like a bug) and select “build.” it should download the proper versions of all the libraries and their dependencies (which might lake a few minutes ) and then compile.
If you really, really want to use the Arduino IDE and you can’t get it to compile there, please post a screen shot of your libraries folder for the Arduino IDE (probably in documents/Arduino/libraries or something similar). Make sure the screen shot shows everything. Also go to the Arduino IDE’s library tool and list out all the libraries and versions it shows are installed. Post the screen shot , your corrected code , and the full error log your getting so I can try to figure out where to help next.
2020-02-12 at 12:21 PM #13804
Thanks.
So, that helped to eliminate most of the compiling error that I was receiving. I’ve attached the error message as I’m getting it right now.
As for the libraries, I’m 99% sure I’ve deleted all duplicate versions of the libraries, so i’m not sure where it is finding the duplicate versions. I’d be happy to try out using PlatformIO. Going back to it now I remember why I gave up trying to use it a few months ago. Every time I start VScode it tries to install the PlatformIO, but it tells me that “PlatformIO: Can not find working Python 2.7 or 3.5+ Interpreter. Please install the latest Python 3 and restart VSCode.” I have the most recent version of python, Python-3.8.1. Along with that error message is a button to select “I have Python.” If I click that, it pops open an address bar at the top of VScode and asks for the full path to Python/Python.exe. That’s where I’m getting stuck as I am not exactly sure how to give it the correct path to the python.exe
2020-02-12 at 1:49 PM #13806
The path to your Python.exe will likely be:
C:\Users\<your-username>\AppData\Local\Programs\Python\Python38If you don’t find it there, you could try the method described here:
https://stackoverflow.com/questions/647515/how-can-i-find-where-python-is-installed-on-windows-Matt
2020-02-12 at 2:06 PM #13807
Hi Matt,
Thanks. I’ve tried that and am met with “Invalid path to python interpreter.”
The path is C:\Users\Josh Biddle\AppData\Local\Programs\Python\Python38-32
2020-02-12 at 5:15 PM #13808
Hmm, are you able to successfully open the python interpreter at that location? E.g., from Windows command line, enter
1C:\Users\Josh Biddle\AppData\Local\Programs\Python\Python38-32\python.exe -
2020-02-13 at 9:01 AM #13809
Yes, I can open python by entering the location from CMD and Run.
2020-02-13 at 9:10 AM #13810
I had some issues with Python when switching to PlatformIO from the Arduino IDE.
I had an older version of python installed, so I thought I would be slick and update before installing Visual Code and the PlatfromIO plugin. That is where I messed up and PlatformIO was pissed.
What alleviated my issues were completely uninstalling all python and Visual Code bits, and reinstalling them together. When you download and install the PlatformIO plugin it looks for the path to the python.exe. If it can’t find it, or you tell it incorrectly, and it is crazy picky on the verbiage, it will become upset and provide you a link to go download it. Do this, and follow the prompts. Make sure you check the box to add python to the path! this is critical.
Ensure that your path is correct within PlatformIO, but if you let PlatfromIO take the wheel it will remember where it was saved.
Having only ever played with the Arduino IDE, I too struggled to get PlatfromIO going. But it is superior and I probably won’t go back to the Arduino IDE.Good luck!
2020-02-13 at 9:36 AM #13811
Hi Sara,
Not sure what I was doing wrong initially but I’ve managed to get platformIO installed correctly on VSCode and I’m ready to proceed.
For step two of your instructions above – “2. After your project is created, delete the contents of the new platformio.ini file and replace them with the contents of the same file from the folder where you copied your code from on GitHub” – what files/code do you mean exactly? The DRWI_CitSci.ino, once corrected, is what will go in the src/main.cpp location correct?
2020-02-13 at 9:38 AM #13812
Thanks Evan. I managed to enter the correct path and I’ve satisfied VScode for the time being. Not sure what I was doing wrong originally, but I try to not ask too many questions. Thanks!
2020-02-13 at 6:50 PM #13813
Correct. 🙂
The platformio.ini you need is here: https://github.com/EnviroDIY/ModularSensors/tree/master/examples/DRWI_CitSci
I’ve had problems with the python path before, not just with platformio, but with other programs as well. I’ve had to uninstall and re-installed all of python and anaconda several times over the years. It’s not been a huge number of times, but I haven’t ever tracked down the reason it got screwy. I’ve kind-of accepted that as an annoyance of python.
2020-02-13 at 8:06 PM #13814
Great, thank you! So far so good. The other step I’m hung up on now is installing the libraries through platformio. I’ve entered the command
pio lib -g install https://github.com/EnviroDIY/Libraries.git#platformio
into the platformio terminal, and have received this error: Error: Please install Git client from https://git-scm.com/downloads
I’ve installed the Git client but when entering the command I’m receiving the same error. Any clue what to do here?
2020-02-14 at 10:46 AM #13815
The git problem is probably another “path” issue. Did you add git to your “path” when you installed it? I don’t remember if the installer gives you the option.
Try checking your path and adding the directory where git installed to it. The git executable (git.exe) is probable installed in “C:\Program Files\Git\bin” Here are some instructions for adding a directory to the path: https://helpdeskgeek.com/windows-10/add-windows-path-environment-variable/
2020-02-14 at 4:07 PM #13816
I did not add git to your path when I installed it, but I followed the instructions on the page you provided and added the location, which was C:\Program Files\Git\bin and I am still getting the same error.
2020-02-14 at 4:36 PM #13817
Hm. Did you restart VSCode after changing the path? Can you open up a new terminal and successfully run git?
I’m sorry; I know dealing with these setup things can be really frustrating. I really appreciate you working through it on the forum where it might be able to help someone else, too. It’s been such a long time since I first started out that I forget the beginning steps.
2020-02-17 at 10:19 AM #13824
That worked! I restarded VSCode and entered the command again and successfully installed the libraries.
I then went back and tried to “build” the program and ended up with a few errors. I’ve again attached the output in a txt file.
That’s alright, thanks for taking the time to walk me through this. I wish I had a bit more experience doing this kind of thing, but I’m learning along the way.
2020-02-20 at 1:27 PM #13827
I’m sorry! It looks like it somehow missed the dependencies in the install. Try running the command
pio lib install EnviroDIY_ModularSensors
2020-03-04 at 11:39 AM #13892
Thanks Sara.
I ran that command in the PlatformIO terminal and was met with another error which I’ve attached here. Once again thanks for taking the time to walk me through this. Hopefully we’re near the end of troubleshooting!
2020-03-05 at 10:37 AM #13902
Huh. It’s an “access is denied” error. I’m guessing two processes tried to write to the same temporary folder – the automatic “check for new libraries in the library folder” process and the manual install probably collided. Did you get the same error multiple times after exiting and reopening?
2020-03-05 at 2:01 PM #13905
For some reason I haven’t gotten it into my head yet to just close the program and try again.
I did that, twice. The second time it seemed like it made some more progress before another error. So I closed the program and tried again and I think this time everything seemed to work. I’m not seeing any more errors and it looked like the libraries were installed correctly. I attached the contents of the terminal for you to verify that.
Seeming like there were no issues with the library this time I tried to build function again and this is what I am now met with (attached below as build_error).
2020-03-05 at 2:03 PM #13906
Here are the attachments.
2020-03-05 at 2:05 PM #13907
For some reason I can’t leave a comment with more than one attachment.
2020-03-05 at 2:17 PM #13910
There’s probably a missing semi-colon or brace in your program code somewhere right above line 215.
Check first where you pasted in the UUID’s. Each UUID should be enclosed with quotation marks, there should be a semicolon after both the registration token and the sampling feature and a comma after each UUID/variable in the UUID list.
You can also check for matching braces by clicking each starting brace/parenthesis. VSCode should highlight its corresponding closing brace so you can see if they’re closed appropriately.
2020-03-17 at 11:01 AM #13941
Thank you Sarah, I managed to fix those issues.
I’ve attached the most recent error message and the code as it exists right now. The first “serial” that it mentions in the error on line 242 is the first “serial” under the Main Setup Function section of the code. It doesn’t look like I’m missing any closing braces so I’m not sure what the issue is here. Thanks again for your help.
2020-03-17 at 11:15 AM #13945
In line 239/240 you’re missing the opening brace of the setup function. It should be
void setup() {
with that opening curly brace. You can put the curly brace right after the parenthesis on line 239 or by itself on line 240.
Missing braces and semi-colons are such a pain. The error messages they usually cause don’t help much.
Also, your code is missing the “loop()” function – it will set everything up and then do nothing. You probably want to add this loop (just paste it at the end of your current code):
C++123456789101112131415161718192021222324// ==========================================================================// Main loop function// ==========================================================================// Use this short loop for simple data logging and sendingvoid loop(){// Note: Please change these battery voltages to match your battery// At very low battery, just go back to sleepif (getBatteryVoltage() < 3.4){dataLogger.systemSleep();}// At moderate voltage, log data but don't send it over the modemelse if (getBatteryVoltage() < 3.55){dataLogger.logData();}// If the battery is good, send the data to the worldelse{dataLogger.logDataAndPublish();}} -
2020-03-17 at 2:42 PM #13948
I’m catching on to that! I’m now faced with a new series of errors – “expected constructor, destructor, or type conversion before ‘(‘ token” is coming up on several different lines. I attached the new error message.
It’s obvious that the code is just missing various braces, brackets, semicolons and the like. I was under the impression that I would be able to take the DRWI_CitSci code, edit in my unique values and I shouldn’t have to make much changes beyond that. I just don’t have the experience or know-how to understand what is missing or needs to be changed, even with the error messages. So sorry for the back and forth.
Should the loop function code go at the very end of my code after everything else?
2020-03-17 at 3:50 PM #13952
Well, it really is that “easy.” “All” you do have to do is create a new project/program, make sure it’s completely blank, copy and paste the example from GitHub into your new project, select precisely each UUID and delete the example junk text, select and copy the real UUID from the MonitorMW webpage and paste it in exactly the place you removed the example from, repeat that 7+ times, install all the libraries correctly, and compile and flash your Mayfly. That’s it.
It just that it’s actually kind-of tricky to make sure you’ve selected exactly the right text when you’re doing all the copy-pasting and if you didn’t remember to start with something blank at the beginning things get mixed up and then you have to start deleting and fixing and then you end up in this mess.
Looking back at the old threads.. I told you to delete the loop because you had other junk after the end of the loop and I went back too many line. Doh. Totally my fault.
After adding the opening brace I mentioned in line 239 and adding the loop at the very end, after everything else, your program compiles fine for me. Did you by chance accidentally add both an opening and closing brace instead of just the opening one? The editor helpfully adds the closing brace for you when you type the opening one.
2020-03-17 at 3:51 PM #13953
Here’s your program that compiled correctly for me.
2020-04-14 at 5:23 PM #14072
Hi Sara,
Thanks so much for your help. Making those changes to the code you last mentioned worked and it compiled successfully! I was able to upload to the board and that feels like a huge step. Thank you! I’m now monitoring the output from the board on VScode and everything seems to be in order except for the sim card. You can see in the attached txt file that the output values for the sim card signal strength are -9999. I have let the program run for a while now and nothing seems to be uploading to monitormywatershed. I checked the sim card on hologram’s website and it is active and connected to the network but not sending any data. So I assume there is either an error in the code or a problem with the physical connection with the board. Any idea where to start troubleshooting this?
2020-04-15 at 4:22 PM #14074
You didn’t manage to connect to the internet for the clock sync. I’m not sure why that happened.
The modem values won’t update in sensor testing mode and they’re always updated at the *prior* internet connection. Since you didn’t connect successfully for the clock sync, they didn’t update.
2020-04-15 at 4:31 PM #14075
I think I’m following. So how do I go about fixing that?
2020-04-15 at 4:36 PM #14076
Working on it right now for you. It will be a library update. The lack of modem update in sensor testing mode was an oversight; I want it to be there automatically.
2020-04-16 at 12:32 AM #14077
I’ve pushed what I think should fix the testing mode to the develop branch of the ModularSensors library, but I haven’t actually tested it myself yet.
I’ll see if I can get it tested tomorrow and then pushed to the master branch.
2020-04-16 at 10:03 AM #14079
Great! Thank you for taking the time to help me with this and trying to update the library.
2020-04-21 at 10:47 AM #14089
Hello Sara,
I just wanted to check in to see if you have had any luck with updating the libraries for this. Thanks.
2020-04-28 at 5:10 PM #14104
Hi again, Sara. Just wanted to check in and see if you had any success with this. I would like to be able to finish up the programming of the board so I can finally get it in the field to start collecting data. Thank you!
2020-04-28 at 5:11 PM #14105
I’m so sorry. I haven’t tested it yet.
2020-04-28 at 5:15 PM #14106
No apology necessary, it had been a little while so I just wanted to check in and see if there had been any progress. Thank you for the update.
2020-05-05 at 9:40 AM #14116
Hello Sara, sorry to bother you but I wanted to check in again about this.
Is there something I could do in the meantime while you work on the testing mode update? Is there a way I can try to fix the connection issue without using the testing mode? Thanks.
2020-05-05 at 11:19 PM #14117
I’m sorry. I finally fixed pushed what I think should be the changes needed to the develop branch, but I still haven’t programmed an actual board to test it. You should be able to test it yourself by listing the develop branch from git in your dependencies. (In the platformio.ini replace “ModularSensors” with https://github.com/EnviroDIY/ModularSensors.git#develop)
This everyone being home all the time situation is brutal. Anyone doing well with it is clearly a lot more disciplined and organized than I am.
2020-05-08 at 3:40 PM #14118
I totally understand. I’m thankful that I’m still able to work full time from home it has been incredibly challenging. But I totally get it and it it’s totally understandable. Thanks again for taking the time to help me with this.
The lib_dep part of the platform.ini says:
lib_deps =EnviroDIY_ModularSensors@0.23.16; ^^ Use this when working from an official release of the library; https://github.com/EnviroDIY/ModularSensors.git#develop; ^^ Use this when if you want to pull from the develop branchSo should I replace the whole line that says “EnviroDIY_ModularSensors@0.23.16” with the link? -
2020-05-14 at 5:46 PM #14163
I just added another fix for the XBee wifi and the modem-measured battery voltage. Have you been able to get it to work for you?
2020-05-20 at 9:52 AM #14173
I have not, I’m still getting this when I monitor the output:
“Attempting to connect to the internet and synchronize RTC with NIST
Could not connect to internet for clock sync.”This is exactly what I have for the lib_dep portion of the platformio.ini:
lib_deps =; EnviroDIY_ModularSensors@0.23.16; ^^ Use this when working from an official release of the libraryhttps://github.com/EnviroDIY/ModularSensors.git#develop; ^^ Use this when if you want to pull from the develop branchIs that what it should look like? -
2020-05-28 at 11:17 AM #14175
Hi Sara, any other thoughts on what I can do to troubleshoot this issue?
