Email alerts rough draft. Free to use
Home Forums Miscellaneous Email alerts rough draft. Free to use
    • #17963
      marbles
        Hey everyone! Here is a python program I wrote that downloads the csv file from monitor my water shed about a specific site and allows you to set up email alerts based on the readings. I will clean it up and put it on github eventually but if you want to check it out and play around it is posted below! Any suggestions or questions are welcome.
        Requirements:
        smtp server/account (elastic mail or sendgrid)
        a computer that’s on 24/7 or a cloud computing account. (google cloud or amazon cloud computing)
        I run this on a google cloud machine 24/7 but I think I’m going to switch to an amazon webserver soon as I believe they have a free option that will work.
        # Email Alerts for Strawberry Creek restoration program. #
        # This program downloads sensor csv data of mayfly’s located around UCB campus from envirodiy.com. #
        # It allows you to program email alerts to a the list below if a threshold is met. #
        # The threshold is measured in standard deviations either above or below the mean and can be changed #
        # by adjusting the cushion values. The larger the cushion the more extreme of a deviation is needed to trigger an email. #
        # The time_between_readings variable should be set to the mayfly it is monitoring. The cycles until next alert variables #
        # allows you to choose how often to get consqeutive alerts about the same reading. #
        # Written by Andrew Glaros #
        # Last edited by strawberry creek intern Andrew Glaros on 6/28/2023 #
        from datetime import datetime, timedelta
        import requests
        import csv
        import time
        import io
        import pandas as pd
        import numpy as np
        import smtplib
        from email.message import EmailMessage
        #below are variables that can be changed to coustomize this program.
        site_name=’Grinell’
        url = ‘url that links to csv file of site of interest’
        #Location:Roach Menos EH&S
        email_list=[’email_1@gmail.com’, ’email_2@gmail.com’] #who to send alerts to. Email addresses must also be added to elaticemail.com contacts.
        #smtp account info
        username = ’email_associated with smtp account’
        pswd = “password for smtp accound”
        url_email= ‘url to be sent in the body of the email’
        smtp_sever_url = “smtp.elasticemail.com”
        smtp_port=2525
        fromAddr = ’email associated with smtp accound’
        #cushions are measured in standard deviations.
        temp_trigger_cushion=2.8
        cond_trigger_cushion=2.7
        depth_trigger_cushion=2.8
        #battery_trigger_cushion=2.8 not in use
        #should be set to the same as the mayfly. measured in seconds
        time_between_readings=180
        #hours to go back to find average and sd
        hours=48
        #how long until next email is sent. (Mininun time between alerts = cycles_until_next_alert * time_between_readings)
        cycles_until_next_alert_voltage=10
        cycles_until_next_alert_temp=10
        cycles_until_next_alert_cond=10
        cycles_until_next_alert_depth=10
        # Only edit under here if you want to change the code yourself #
        import requests
        import csv
        import time
        import io
        import pandas as pd
        import numpy as np
        import smtplib
        def threshold(array,name,cushion):
        mean=np.mean(array)
        std=np.std(array)
        high_end=mean+cushion*std
        low_end=mean-cushion*std
        print(‘current ‘, name,’:’, array[-1], ’48 hour mean:’,np.round(mean,3), ‘ 48 hour std: ‘, np.round(std,3))
        return [low_end, high_end]
        def send_email(array, name):
        toAddr = email_list
        subject = ‘Creek Alert’
        msg = EmailMessage()
        msg[‘From’] = fromAddr
        msg[‘To’] = ‘, ‘.join(toAddr)
        msg[‘Subject’] = subject
        current_reading=np.round(array[-1],3)
        mean=np.round(np.mean(array),3)
        std=np.round(np.std(array),3)
        body = f’Email for {name} was called from the {site_name}.\nThe current reading is {current_reading}. The 48 hour mean is {mean}. The 48 hour sd is {std}\n\nSensor URL: {url_email}’
        print(body)
        msg.set_content(body)
        smtp_sever = smtplib.SMTP(smtp_server_url, smtp_port)
        server.login(username, pswd)
        server.send_message(msg)
        server.quit()
        def condition_tester(low_end,high_end,array,name):
        if float(array[-1])<=low_end or float(array[-1])>=high_end:
        send_email(array,name)
        return True
        voltage_count , temp_count , cond_count , depth_count = cycles_until_next_alert_voltage-1, cycles_until_next_alert_temp-1, cycles_until_next_alert_cond-1, cycles_until_next_alert_depth-1
        while True:
        voltage_count += 1
        temp_count += 1
        cond_count += 1
        depth_count += 1
        response = requests.get(url)
        if response.status_code == 200:
        csv_data = response.text
        # Skip the header line and lines starting with a hash symbol
        csv_data_lines = [line for line in csv_data.splitlines()[1:] if not line.startswith(“#”)]
        # Create a StringIO object to simulate a file-like object
        csv_file = io.StringIO(‘\n’.join(csv_data_lines))
        try:
        df = pd.read_csv(csv_file)
        df[‘DateTime’] = pd.to_datetime(df[‘DateTime’]) # Convert to datetime data type
        # Calculate the starting point for the last 48 hours and filter table
        current_time = datetime.now()
        start_time = current_time – timedelta(hours=hours)
        last_48_hours_data = df[df[‘DateTime’] >= start_time]
        # get the data in arrays
        voltage_array=(last_48_hours_data[‘EnviroDIY_Mayfly_Batt’]).values
        temp_array=(last_48_hours_data[‘Meter_Hydros21_Temp’]).values
        cond_array=(last_48_hours_data[‘Meter_Hydros21_Cond’]).values
        depth_array=(last_48_hours_data[‘Meter_Hydros21_Depth’]).values
        except pd.errors.ParserError as e:
        # Print the error and the problematic line
        print(“ParserError:”, e)
        print(“Problematic line:”, csv_data_lines[62])
        # if voltage_count>=cycles_until_next_alert_voltage:
        # low_end_threshold_voltage , high_end_threshold_voltage = threshold(voltage_array,’voltage’,battery_trigger_cushion)
        # reset=condition_tester(low_end_threshold_voltage,high_end_threshold_voltage,voltage_array, ‘voltage’)
        # if reset==True:
        # voltage_count=0
        if temp_count>=cycles_until_next_alert_temp:
        low_end_threshold_temp, high_end_threshold_temp = threshold(temp_array,’temp’,temp_trigger_cushion)
        reset=condition_tester(low_end_threshold_temp,high_end_threshold_temp,temp_array, ‘temp’)
        if reset==True:
        temp_count=0
        if cond_count>=cycles_until_next_alert_cond:
        low_end_threshold_cond , high_end_threshold_cond = threshold(cond_array,’cond’,cond_trigger_cushion)
        reset=condition_tester(low_end_threshold_cond,high_end_threshold_cond,cond_array, ‘cond’)
        if reset==True:
        cond_count=0
        if depth_count>=cycles_until_next_alert_depth:
        low_end_threshold_depth , high_end_threshold_depth = threshold(depth_array,’depth’,depth_trigger_cushion)
        reset=condition_tester(low_end_threshold_depth,high_end_threshold_depth,depth_array, ‘depth’)
        if reset==True:
        depth_count=0
        else:
        print(“Failed to retrieve data. Status code:”, response.status_code)
        time.sleep(time_between_readings)
      • #18548
        Scott Ensign
          Hi Andrew. Thanks for sharing this code; I hope others have been able to implement this. @brianjastram recently asked if an “alarm” feature would be built into Monitor My Watershed (hopefully someday as resources allow). Until then, I suggested that your code might benefit from the work @srgdamiano did to specify parameter and time/date range queries to Monitor My Watershed: https://gist.github.com/SRGDamia1
        • #18551
          marbles
            Hey Scott Thank you the suggesion! I am finishing up a django web-app so folks can implement alarms with rain pauses without any coding. I will be sure to include srgdamiano‘s code to make things more efficient!
            Here is a demo of the alarm app if anyone is intersted!
            https://drive.google.com/file/d/1pJZPLYKRPVoxTfKJQ0nbDjkDVVvbkRvg/view?usp=sharing
