Home › Forums › Mayfly Data Logger › Error Compiling for board EnviroDIY Mayfly 1284p
- This topic has 11 replies, 4 voices, and was last updated 2025-03-13 at 11:17 PM by
Stephen H.
2024-11-25 at 2:58 PM #18762
I am trying to upload the sketch through the following instructions (ModularSensors/examples/DRWI_NoCellular at master · EnviroDIY/ModularSensors · GitHub)
I followed all the directions but when I try to verify or upload the sketch through Arduino onto our Mayfly, I get the following error message –
<p style=”text-align: center;”>exit status 1
Error compiling for board EnviroDIY Mayfly 1284p.</p>
I am a complete beginner to this and was wondering if I could get any guidance on solving this issue.Thank you.
2024-11-25 at 3:28 PM #18763
Have you installed all the supporting libraries into your Arduino/libraries folder? There should be either 32 folders worth of libraries, or 47, depending on whether you downloaded all the recommended EnviroDIY libraries, or just the ModularSensors dependencies.
2024-11-25 at 4:26 PM #18764
Yes, I believe I have. It looks like I downloaded all recommended EnviroDIY libraries (47). Do I need to do anything with them once I have them in my library folder? Do I need to install all of them in Arduino somehow?
2024-11-25 at 5:20 PM #18765
The unzipped folders go into your MyDocumenrs/Arduino/libraries folder. Make sure they aren’t nested within a second ‘libraries’ folder within the first one. What version of the IDE are you using?
A good way to check that your libraries are installed correctly is to look at the built-in examples. In the ARduino IDE, go to the File dropdown menu, then select examples. You should see the basic Arduino example, then some more complex ones, but keep scrolling to the bottom and you should see lots of other ones like Adafruit and ModularSensors and SDI12. The sketch you’re trying to use should be included under the ModularSensors list. If you don’t see it, then your libraries aren’t installed correctly.
If your libraries are correct, there should be more information in the error window that will tell you what is causing the problem. If you still get the error, copy that full error message into your post.
2024-11-26 at 10:29 AM #18766
I am using Arduino 1.8.19
I checked the libraries using your method and I do see all the examples and the sketches under the ModularSensors list.
I now ran into another problem which I believe is related to the DS3231 clock. I was able to set the time correctly using the directions from this page – 4. Preparing the Mayfly Data Logger – EnviroDIY
However, when I tried to upload the sketch for DRWI_NoCellular, I got the following error window:
Arduino: 1.8.19 (Windows 10), Board: “EnviroDIY Mayfly 1284p”
C:\Users\Documents\Arduino\libraries\EnviroDIY_ModularSensors\src\sensors\MaximDS3231.cpp: In member function ‘virtual bool MaximDS3231::startSingleMeasurement()’:
C:\Users\Documents\Arduino\libraries\EnviroDIY_ModularSensors\src\sensors\MaximDS3231.cpp:46:33: error: no matching function for call to ‘Sodaq_DS3231::convertTemperature(bool)’
rtc.convertTemperature(false);
In file included fromC:\Users\Documents\Arduino\libraries\EnviroDIY_ModularSensors\src\sensors\MaximDS3231.cpp:10:0:
C:\Users\Documents\Arduino\libraries\Sodaq_DS3231\src/Sodaq_DS3231.h:73:10: note: candidate: void Sodaq_DS3231::convertTemperature()
void convertTemperature();
C:\Users\Documents\Arduino\libraries\Sodaq_DS3231\src/Sodaq_DS3231.h:73:10: note: candidate expects 0 arguments, 1 provided
exit status 1
Error compiling for board EnviroDIY Mayfly 1284p.This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences. -
2024-11-27 at 10:29 AM #18767
Are you trying to use the that NoCellular sketch as-is, or have you modified it before attempting to upload it?
2024-12-03 at 10:34 AM #18773
I have modified the sketch by replacing the UUID list in the original NoCellular sketch with my UUID list from Monitor My Watershed.
2024-12-03 at 2:54 PM #18774
The warnings you posted above seem to indicate that there’s a clash with the Sodaq DS3231 library. Did you by chance happen to install that library separately into your Arduino/libraries folder? ModularSensors already includes its own version of the DS3231 library which will conflict with the Sodaq library if they both exist on the same computer.
2025-01-21 at 4:25 PM #18841
I figured out the issue but I am now facing another error. I keep getting the following error message –
C:\Users\Documents\Arduino\libraries\EnviroDIY_ModularSensors\src\sensors\AlphasenseCO2.cpp:17:10: fatal error: Adafruit_ADS1X15.h: No such file or directory
#include <Adafruit_ADS1X15.h>
compilation terminated.
exit status 1
Error compiling for board EnviroDIY Mayfly 1284p.Any help would be appreciated. Thank you.
2025-01-22 at 2:07 PM #18842
It looks like you’re having the same issues a few other people have reported lately. We’re working on a fix, but in the meantime, the easiest thing to do is to replace all your “MyDocuments/Arduino/libraries” files with the stable versions from last summer. In order to do this, you’ll have to delete all the current library files on your PC. If you’re only using a Mayfly board with the standard sensors and accessories we typically recommend, and you haven’t downloaded other library files for other non-EnviroDIY devices or equipment, then it’s fine to delete all your library files. If you HAVE downloaded other non-EnviroDIY library files for other things, then don’t proceed because you’ll delete the files for those other things. Otherwise, follow these instructions:
First, close the Arduino IDE (it’s best to do this without the IDE running). Then use Windows File Manager (assuming you’re on a windows PC) to browse to MyDocuments/Arduino.
In there you’ll see any customized sketches you’ve saved, plus a folder called “libraries”
Double click on “libraries”, and in that folder you should see about 45 folders (if you’re using the most recent version of ModularSensors and it’s dependencies). Highlight them all (using Ctrl+A) and then hit Delete key (or right click on them with the mouse and choose Delete).
Now you should have a libraries folder that is completely empty.
Now use your browser to visit this page: https://github.com/EnviroDIY/ModularSensors/releases
Scroll down to the May 17, 2024 entry which is for version v.0.35.0
At the bottom of that section, click on “Assets” and you should see 3 files listed. Right-click on the one called “ModularSensors_Dependencies_v.0.35.0.zip” and save the file to your computer.
Now use windows File Manager to double-click on that zip file. Inside it you should see 32 folders. Select all of them, hit Ctrl-C to copy (or right-click and Copy). Then switch to the empty “libraries” folder within your “MyDocuments/Arduino” folder, and paste the 32 directories into the libraries folder.
You have now installed the old, stable versions of the library files. Restart your Arduino IDE and you should still have all your saved personal sketched in the Sketchbook, and when you compile the sketch for your logger, you should have no errors now.
2025-03-07 at 6:24 PM #18973
I was getting the same error message as the poster above, so I went ahead and followed the instructions that Shannon provided to fix it (2025-01-22 at 2:07 PM), but now I am getting this error message that I attached. That is one of 10ish errors that I am getting.
When checking out the libraries folder, everything seems in order.
The previous library worked fine for 2 sketches that I uploaded, an address change sketch and an analog serial reading sketch that Shannon provided here: https://www.envirodiy.org/topic/continous-hab-monitoring/, but when I went to upload the DRWI modified sketch I get the AlphasenseCO2.cpp:17:10: fatal error: Adafruit_ADS1X15.h: No such file or directory
#include <Adafruit_ADS1X15.h> error.My libraries are in a OneDrive documents folder.
2025-03-13 at 11:17 PM #18986
A few of the folders in “ModularSensors_Dependencies_v.0.35.0.zip” are named with blank spaces or with longer names, if you go into any of the folders with spaces, copy the name of the .h file and rename the folder to that name, it works.
ie
Adafruit ADS1X15 rename to-> Adafruit_ADS1X15
Adafruit BME280 Library rename to -> Adafruit_BME280
etc….
That should resolve your problem.
