Errors compiling DRWI_SIM7080LTE.ino code
Home Forums Mayfly Data Logger Errors compiling DRWI_SIM7080LTE.ino code
Viewing 7 reply threads
    • #16283
      Jim Moore
        @damiano – I am attempting to upgrade my LEC stations to the new 4G s
        Simcom boards and I am getting compile errors relating to “NeoSWSerial.cpp”.  I attached a screen shot of the error message. Any suggestions would be appreciated.
      • #16289
        Jim Moore
          <h2 class=”user-nicename”>@srgdamiano</h2>
          Hi Sara-
          I spelled your handle wrong so maybe you didn’t see this.  Do yo need more details?
        • #16325
          Jim Moore
            @srgdamiano @hicks
            Current status of my problem; I am using the 0.5 Mayfly board and have changed to appropite line from 18 to -1 and I get compile errors related to NeosWSerial.ccp.  I have updated all my libraries and still get the same error.
            If I comment out the lib entry for NeoSWSerial the sketch compiles but when loaded the console output appears normal but the simcon board doesn’t come on so I assume the NeoSWSerial is needed and the program doesn’t default to another SWSerial function.
            Help!
          • #16327
              Are you using the new sim7080 directly plugged in to the Mayfly, or are you still using the LTEbee adapter board from your old Digi hardware in between the sim7080 and the Mayfly?
            • #16328
              Jim Moore
                The new sim7080 is plugged directly into the Mayfly 0.5b.
              • #16329
                Jim Moore
                  I assume that the NeoSWSerial function is needed. to talk to the sim7080 and that is why I am not getting any response from the modem
                • #16330
                    Email me your sketch and I’ll load it to a v0. 5b board and see if I can recreate your issue.
                  • #16331
                    Jim Moore
                      @shicks
                      I emailed the sketch and the associate pio .ini file.
                      Thanks for looking into this.
