We are looking at adding an external circuit breaker to protect a monitoring kit. We are configuring a monitoring kit to be a mobile or portable unit, that can be carried aboard a ship/boat of opportunity. Often in the field on a boat or in some weather, equipment gets wet.
What level of current should an external breaker be rated to prevent damage in the event of overcurrent? Usually it is set above the max current draw, but not so close to the operating peak to constantly trip the breaker during normal operation (above 2 amps?) We would likely use a hydraulic magnetic breaker.
Tony
<!–more–>
