Hydros 21 CTD – Losing connection? [SOLVED]
Home Forums Environmental Sensors Hydros 21 CTD – Losing connection? [SOLVED]
Viewing 4 reply threads
    • #15581
      James_NZ
        I am testing a Mayfly setup with a HYDROS 21 CTD and a Yosemitech 511-A turbidity sensor. The Turbidity sensor is working well, but the CTD seems to intermittently dropping in and out (see attached MMW plots).
        Any thoughts on what might cause this? I have set the CTD address to channel 1 as per instructions. I did notice that the ‘sdi12_address_change.ino’ script went haywire until I removed the Modbus WingShield, so I wonder if the Y511-A is interfering with the CTD signal? The Y511-A is set to address 0x01 as per factory settings.
        Thanks in advance for your help.
      • #15584
          Does your Modbus wingshield do any level shifting of the CTD’s SDI-12 data line?  Is there anything on the wingshield tied to whatever Mayfly pin you’re using for the data line (I’m assuming D7)?
        • #15585
          James_NZ
            Hi Shannon,
            Yes I am on D7 for the CTD. I am using the default pins for the mayfly modbus wing (https://github.com/EnviroDIY/Mayfly-Modbus-Wing/tree/master/Modbus-Mayfly_WingShield):
          • #15586
            James_NZ
              I have switched my pin for the HYDROS 21 CTD from D7 to D11, but I seem to be having the same issue.  It’s worth noting that I don’t get -9999 values when plugged into my computer.  Could it have something to do with power?
              My code is below.
            • #15587
              James_NZ
                I had a lightbulb moment today that seems to have fixed my problem.  I switched the 3.3v jumper to 5v.  Success!!  I guess it was brown-out.
