Home › Forums › Environmental Sensors › Logging data from Milone eTape
- This topic has 5 replies, 2 voices, and was last updated 2025-04-17 at 5:35 PM by
2025-04-07 at 3:48 PM #19029
Hi –
I am a newbie to the world of Arduino/MayFly and would like to create a system to regularly log the output from a Milone eTape sensor that will be installed on the side of a flume outdoors. This is the sensor: https://milonetech.com/shop/ols/products/xn-standard-etape-assembly-75a-a8ed96
I have contacted Milone and it sounds like the pre-calibrated sensor with the 0-3.3 VDC resistance to voltage output module would be the way to go for highest precision. This unit has a 3-pin JST connector for power, ground in, and analog signal out.
My question is what is the best way to connect the 3-pin JST connector to a MayFly board? Based on other forums (like this one), it sounds like it should connect to the MayFly’s ADS1115. But how exactly does that happen? Any help would be much appreciated!
2025-04-07 at 10:57 PM #19032
Hi Eric – I’ve purchased and looked at using the eTape.
I was just wondering what made you think they are “calibrated” – that is the “0.0” markings relates to a defined voltage. Usually this is shown for a calibrated sensor. Similarly for a Full Scale relates to a known Voltage.?
looking at the graphs, they describe “0-5VDC Linear Resistance to Voltage Module PN-05V00199 REV 2” but no graphs of 0.0 to V
Be interested if you find that they have it calibrated .
2025-04-08 at 2:56 PM #19033
Thanks for the response, Neil. I’m basing the idea that the sensor is calibrated on the following response from Milone when I asked about the difference between the standard voltage divider setup and the other more expensive (+$45) output modules:
“<span data-olk-copy-source=”MessageBody”>If you go with the standard voltage divider, each sensor would have to be characterized/calibrated individually. We calibrate sensor assemblies with the 0-3.3V/0-5V output modules in house before sending them out. Therefore, the latter will give you the best accuracy.”</span>
2025-04-08 at 9:17 PM #19034
Good to hear. and definitely very interested in use with a flume. What range of water depth measurement are you looking for and depth accuracy of measurement.
Typically, because ADCs are not good around 0.0V and rail – the Sensor range from 0.0 to full range, the Voltage range is from 10%Rail to 90%Rail (eg 0.3V to 3.0V for 3.3VDC rail) and typically wants to be ratiometric. That is the ADC voltage VREF is the same as that used by the sensor. The other way of adjusting that is that the measuring device has a greater range than the actual range of measurement. That is 0.0 is less than the flume entrance.
Resistance varies with temperature (as everything in the universe varies with temperature)- so they haven’t listed what the temperature dependency is. It might not be much in the water, and may need a reasonable shield for that out the water.
How are you looking to power it, Are you looking to report it wirelessly? Standard ModularSensors is best effort in both cases.
2025-04-15 at 2:57 PM #19040
Sorry for the delay. I’m planning to use it in an H-flume that has a maximum depth of 0.45 meters. It looks like precision is listed as 0.25 mm but I’m okay with accuracy closer to 2 mm.
And thanks for the sensor range info. I’ll plan to install the eTape in a probe well attached to the flume that extends below the flume entrance elevation. I will plan to test it for changes in temperature (air and water).
I’m hoping to power it directly from the MayFly with a LIPO battery. And yes, I’m hoping to lean on the ModularSensors library even though the eTape sensor is not listed as a supported sensor: https://github.com/EnviroDIY/ModularSensors?tab=readme-ov-file#supported-sensors
Any help on how to navigate that process? Thanks in advance!
2025-04-17 at 5:35 PM #19067
Hi Eric. this is a voltage sensor, so it fits a pretty basic type of sensor, measure the voltage and then translate it to depth.
For a sensor, layers of calibration give value. Calibration of the sensor to defined units (V to mm), and calibration of the water height to the measured height in the flume.
The accuracy sounds pretty reasonable, for a visual check can probably can only get to +/ 1mm visually under ideal circumstance. There are some good ideas of attaching the sensor into the water https://www.envirodiy.org/knowledge-base/ Sect 7.3.4 – however each time is going to require mapping to a physical measurement tape line. So how to secuse the milone tape in a a protective pipe and also relate to its calibration. Might be an idea to have a see through protective plastic pipe, to map milone tape measurements to external physical reading
For the milone tape output, the auxiliary ADC. ADS1115 gives the most accuracy with an input over 0 to 3.3V. You need to decide if running it at switched 3.3V or boosted 5.0V. I would think 3.3V
I did see this discussion, that is using a 0-10V , but would need to scale it to 0-3.3V
https://envirodiy.github.io/ModularSensors/group__sensor__ads1x15.html
I should point out that main ModularSensors is a “scientific software” package – best effort architecture. Nobody is sharing metrics as to how well it works, which is usual practice for engineering types. Engineering is about high reliability, software and hardware. There are some good software examples, but no standard software reference builds. If there is good wireless cell signal, then readings on the server (assuming MonitorMyWatershed ) gives a good visual that the site is operational If the wireless or server becomes unavailable, readings are dropped – however its accessible on the loggers uSd card. If the available power in the battery gets low and not managed the processor starts resetting and needs a site visit and new battery. So I recommend one of your sensor be the battery and also the SampleNumber – a linear number increments each sample and reset to 0 when the processor boots. https://envirodiy.github.io/ModularSensors/group__sensor__processor.html
I’ve done my own fork of ModularSensors to make it as reliable as a “Walking Boot Net”, that is walking up to the logger and copying the uSD to get ALL the time series readings. Features here https://github.com/neilh10/ModularSensors/wiki/1a-Feature-notes
Description of my systems that have been operating in the field for some years https://www.envirodiy.org/n-ca-mayflys-through-the-winter-storms/
I did do a crude Electrical Conductivity sensor – measuring the waters EC through a simple sensor, and no wireless – I don’t think this is going to be that helpful but this is where it is – https://github.com/neilh10/ModularSensors/tree/release1/examples/tu_ec01
Goodluck
