Mayfly Board v0.5b – Communication with MWW
Home Forums Mayfly Data Logger Mayfly Board v0.5b – Communication with MWW
    • #17468
      EMayerRHA
        I seem to be having some problems with a Mayfly ver 0.5b data logger. It has not recorded data since October 29th, nor has it connected to the cellular network since that day. I believe it is the cellular card on the board, but wanted to inquire about functionality because I cannot find documentation on the meaning of the LED indicators. When the board starts up, I am given the red LED light near the reset switch, as well as the two blue lights on the cellular card. The orange RSSI light does not light up. After about 3 minutes, the board goes to sleep and the green LED flashes every few minutes.
        At the programmed 15 minutes, the board wakes up and the red LED by the reset switch lights up as well as the blue lights on the cellular card, but no RSSI light. Are there error messages in the LED lights that I should be aware of that could indicate the problem? Could the cellular card be malfunctioning? Has anyone else experienced this?
        Also, when I connect the board to a laptop via USB, I am given multiple COM ports to choose from. COM 3, COM 4, COM 8, COM 9. Is this normal?
      • #17488
        BrianJastram
          Mayer, if the CR1220 battery powering the internal clock is low on voltage this could be causing a time mismatch and no connection during the cellular connection sequence.
        • #17495
            It sounds like you’ve got one of the older Digi LTE cell boards?  We retired most of ours in 2020 because they failed after a year or two of operation, which is why we developed our own LTEbee module based on the SIM7080.  What does the data on you microSD card say the signal strength and battery voltage is since the station went offline?
