Mayfly Monitoring from Mountains to Estuary
Home Forums Infrastructure and Equipment Mayfly Monitoring from Mountains to Estuary
Viewing 0 reply threads
    • #15404
      James_NZ
        I am planning to deploy a network of Mayfly stations to better understand where and when contaminants are mobilised within a catchment. I am working on a base set of sensors that consists of a decagon CTD, and a turbidity sensor (probably YOSEMITECH).
        The catchment feeds into a highly valued estuary which has become degraded due to excessive land use. The community group that I am working with would like a monitoring ‘buoy’ in the estuary to couple with the Mayfly catchment network that I am proposing.
        I figure that I could easily provide a Mayfly solution to the monitoring buoy, which is likely to be cheaper and allow for more monitoring locations. My plans are to hammer a long pole into the estuary bed and attach a Mayfly station.
        Has anyone attempted anything like this before?
        Are there any thoughts on a sensor set-up to track fluxes from the catchment? Obviously conductivity is not going to be that useful due to salinity, so I might need additional parameters.
        Any other advice?
        Thanks for your time.
