Mayfly Operating Temperature Limits
Home Forums Mayfly Data Logger Mayfly Operating Temperature Limits
    • #1836
      JBurrow
        I have a sensor application that will need to remain outside throughout the winter and will likely see -25 C. What are the operating temperature limits for the assembled mayfly board?
      • #1840
          The circuit components are rated to the industrial temperature range of -40C to +85C, but I think at extreme temperatures you’re more likely to encounter problems with your battery rather than the Mayfly circuit. LiPo batteries don’t perform well at either really cold or really hot temperatures, so you might consider a different type of battery chemistry if you’re deploying it long-term in a harsh environment.
          Last winter, a number of my Mayfly loggers saw -20 degrees on a number of occasions according to the logged temperature of the onboard DS3231.
