Multiple OneWire Sensors Multiple Pins
Home Forums Environmental Sensors Multiple OneWire Sensors Multiple Pins
Viewing 0 reply threads
    • #17096
      KBR Kings River
        I would like to monitor temperature, of water, ground and air.  I was thinking of building one wired sensor to the water, then another wired sensor to ground and air.  Thus I would need two OneWire Bus Pins, .and the one  OneWire Bus pin would have two sensors attached.
        Using a few Arduino Example sketches I can get this to work and read, multiple sensors on multiple buses, using unique addresses.
        However in the ModularSensors a_la_cart example it just has 1 sensor on 1 bus.  I have tried adding an changing some of the const but but cant get to compile.
        How do I change the code to have multiple sensors…   and
        How do I change the code to have multiple OneWire Buses
        Thanks Ron
