Pelican 1120 drilling template
Home Forums Mayfly Data Logger Pelican 1120 drilling template
    • #18991
      nick
        Can someone direct me to a 4 hole drilling template if it exist?
        I found this: https://github.com/EnviroDIY/EnviroDIY_Mayfly_Logger/blob/master/hardware/1120Pelican_enviroDIY_5.pdf
        I thought I found and bookmarked a 3 hole version before, but now I can’t seem to locate it.
        Thank You
      • #18992
          I haven’t seen any other templates besides the one you linked.  I never use them myself, I just lay them out in whatever pattern is the easiest, based on the sizes of the cable glands.  I prefer to stagger them as shown in this photo from the kit’s shop page, since that makes it easier to get your hand around the end part to tighten them.  I use a socket to tighten the nuts on the inside of the Pelican case because an adjustable wrench can’t usually get in there to properly grip the plastic nuts.
