Purchasing individual parts from starter kit
Home Forums Mayfly Data Logger Purchasing individual parts from starter kit
Viewing 5 reply threads
    • #15399
      Cheryl Nolan
        Can these parts be purchased separately?
        <p class=”p1″><span class=”s1″>-1 waterproof enclosure with clear lid (screws and gasket included)</span></p>
        <p class=”p1″><span class=”s1″>-Mayfly microSD connector board</span></p>
      • #15400
          Yes, you can buy the small case separately, in ABS plastic either with a clear lid or an opaque lid:  search the internet for RP1095 or RP1095C and you’ll find multiple vendors.
          There’s also a new version with mounting flange feet if you’re planning to mount the case somewhere where having the flange would be helpful.  Those are model RP1095BF and RP1095BFC
          And if you’re going to be mounting these boxes out in the sun for multiple years, you might want to use their new polycarbonate plastic versions instead of ABS.  They’re a little more expensive but will hold up longer if you’re using them by themselves instead of inside a Pelican case.  They are models RP1090, RP1090C, RP1090BF, AND RP1090BFC
          The Mayfly vertical microSD memory card adapter boards are currently not available separately, but we do offer 5-piece set of them in our EnviroDIY shop.
        • #15401
          Cheryl Nolan
            Great! Thanks Shannon!!
          • #15574
            Rory G
              Just wanted to check if I could purchase only the SD card reader. I have two boards where both SD card readers that had soldering joints fail on them. I would be incredibly appreciative if I could buy just the one replacement part and have someone stick it in an envelope and mail it to a Canadian address.
              If not, I’m out about ~$3,000 in equipment that I sold to a client that now doesn’t work. Lost quite a bit of data and unpaid hours too. Ouch.
            • #15575
                We sell a 5-pack of the vertical microSD card adapter in our online shop:  https://www.envirodiy.org/product/envirodiy-vertical-microsd-card-adapter-pack-of-5/
                We only ship to US address though, so you’ll have to figure out a mail forwarding service for Canada.
                That said, there’s already an onboard microSD card socket on every Mayfly that does the exact same thing, all the vertical card adapter does is allow you to access the card a little easier if you’ve got the board down in an enclosure, so a Mayfly board isn’t useless without a vertical memory card adapter.
              • #15576
                Rory G
                  I’m not sure how I missed the SD card reader on the board. I’ll see if my Tech guy can re-write to that. Thanks!
                  As for shipping, I’ll give one of those forwarders a try.
