Reading from EEPROM error in code
Home Forums Mayfly Data Logger Reading from EEPROM error in code
Viewing 6 reply threads
    • #15184
      James_NZ
        I am trying to write some code to test some new low-cost sensors, including a DFRobot gravity conductivity sensor (https://www.dfrobot.com/product-1123.html).  I have used snippets of DFRobot’s code, and built calculated variable functions in modular sensors to read data.  In this case the DFRobor code uses a ‘k’ value as a crude calibration method, i.e. essentially a scaling factor.  I use a separate calibration script to calculate the k value and store it in the EEPROM, which is retrieved  upon initiation of the modular sensors program.
        This method works if I build a script that only reads and returns the SpC value from the condy sensor.  However, the same line of code returns an error when I combine it with the modular sensor code.
        If I comment out all the references to the EEPROM and use a defined k value instead (e.g. kvalue = 1), the modular sensors code compiles with no problems.
        I usually like to work through coding issues myself but in this case I seem to be overlooking something seemingly simple.  Can anyone see anything obvious that I am missing?
        Thanks in advance for your help.
        Regards,
        My full modular sensor code (please forgive my inefficiencies, I am just learning c++) :
      • #15185
          I think you just missed commenting out one more reference to the EEPROM in line 144: EEPROM_read(KVALUEADDR, Kvalue); //1.0 means no change to raw readings. Just commenting or deleting that line should fix the compiler error.  I would also suggest you delete lines 38-43 so you’re not even trying to include the unused EEPROM library.
          If you wanted to, you could use the “extVoltage” sensor in ModularSensors with >1 reading to simplify all your code for reading the analog values. You would still need to create a calculated variable for the pH, conductivity, and eTape calculated from the voltage.  There’s nothing wrong, though, with reading the value and doing the calculations just as you are.
        • #15186
            If you’re still using the Arduino IDE, you might consider switching to VSCode (or Atom) with PlatformIO.  I know VSCode seems very scary to start with, but if you’re writing new code or even just copy-pasting chunks the linting tools it provides are invaluable.  When I created a project for your code in VSCode, it immediately highlighted the errant EEPROM line.  I know when I try write code of any type without the linter, I always screw up and miss semicolons or other small errors that are really hard to find with your eyes reading the code but which the linter flags right away.
          • #15187
            James_NZ
              Thanks @srgdamiano! I will try again when I get home from work.
              I am using Atom with PlatformIO. How do I turn the linter tools on? thanks also for the tip on ‘extVoltage’. I was going to write a function that did the same thing as the unnecessary repetition was starting to bug me!
            • #15190
              James_NZ
                Hi Sara,
                I worked through this and everything compiles correctly now!  Thanks for your help.
                I did wonder about the linter in Atom.  From what I have read there seems to be an issue with linters working with .ino files in Atom.  Have you guys found anything that works?
              • #15191
                  In case its of interest, I’m using the EEPROMClass from EEPROM.h
                  \.platformio\packages\framework-arduino-avr\libraries\EEPROM\src
                  EEPROM.put(EP_PERSISTENT_STORE_ADDR, epc.app);  where epc.app is a typedef containing all the values to be stored/read from persistent EEPROM.
                  and similarly
                  EEPROM.get(EP_PERSISTENT_STORE_ADDR, epc.app);
                • #15192
                    I’ve been using primarily VSCode for a while because it loads faster on my computer, but I believe I set Atom up to force ino’s as cpp’s:  https://docs.platformio.org/en/latest/integration/ide/atom.html#force-arduino-file-as-c
