I am putting together a micromet station that includes some sdi12 sensors (meter group Terros 21, and Acclima 315H) and some analog thermistors (homebuilt but the same components as the Campbell Sci 107) with a second resistor (24.9K) wired between the return wire and the ground. I have some separate pieces of example code for the SDI12 sensors and the analog thermistors that work ok on their own. I am struggling to put together a logger code that effectively records data on the Mayfly SD card from both the digital and analog sensors. Does anyone have or know of some code that accomplishes this? Any help would be greatly appreciated.
