Welcome to EnviroDIY, a community for do-it-yourself environmental science and monitoring. EnviroDIY is part of WikiWatershed, an initiative of Stroud Water Research Center designed to help people advance knowledge and stewardship of fresh water. New to EnviroDIY?Start here
Hello, the sun is low here at 48 N and we need to run an extension pole for our solar panel.
Can anyone recommend what type or where I can find a ~15′ extension for the solar panel wire? Or just what the connectors are called so I can do some searching? And if using that length it’ll still deliver adequate power/charging to the mayfly?
If you’re talking about the external solar panels that we ship with the EnviroDIY Monitoring Station Kit, they are made by Voltaic Systems, and they offer a variety of extension cables for placing the panel further from the logger. The connector is a basic 3.5×1.1 mm barrel jack, but it has a unique waterproof design that is better for outdoor use than standard barrel jack/plug combos. We’ve used the 4-foot and 10-foot extensions before with good results. You can find their extension cables here: https://voltaicsystems.com/connectors-extensions/
