Yosemitech 511-a starting up twice?
Home Forums Environmental Sensors Yosemitech 511-a starting up twice?
Viewing 0 reply threads
    • #18620
      Stephen H
        Using just the Yosemitech 511a, when it starts up it wipes 3 full times then does a reading.  When I add the code for the Hydros CTD sensor, it seems that the 511a starts up twice and wipes a full 6 times?
        Is this because the sensorPowerPin is the same for the CTD sensor and for the 511a?  Or is my setup configuration incorrect?
        Also anyone know what is the difference between
        const int8_t y511AdapterPower = sensorPowerPin; // RS485 adapter power pin (-1 if unconnected)
        const int8_t y511SensorPower = 22; // Sensor power pin
        sensorPowerPin is defined as 22 as well?
        Thanks for any insight.
